Down/spot wiring | on ElectriciansForums
Discuss Down/spot wiring in the UK Electrical Forum area at ElectriciansForums.net
Uk
Hello..im new here:) im in my first year as an adult trainee and with the current situation have been working alot on my own, my work is being checked over by a qualified spark...anyway more to the point..
Im currently doing a house rewire... So far im doing the lighting...ceiling pendants.
Im moving on to the kitchen which is downlights, im taking the power the switch..the kitchen isnt the last room in the circuit...
where does power cable come from for the next room?
Sorry i am still learning
Diagrams would be amazing
From the plast point you have taken the live pair to, in this case the switch.
Just out of curiosity, when doing re-wires do any of you guys now put a neutral to the switch for future changes to the switch, that need a neutral. Or is it still the norm not to add one.
Ok thanks...do i terminate the next rooms power cable into com on the light switch?
Thanks again
Thanks again
With the L&N you have taken to the switch, same as if you had used the loop in at the light.
The live from last light and live to next next normally go into Common on a switch, but some switches dont mark them as Common, or C... just L1 or something.
The neutrals are put into a connector, but again, some makes of switch come with a common neutral actually on the switch. It has no function, just somewhere to park the N's
Its more and more common to run L+N to switches rather than lights. Smart switches, majority need a neutral, using deeper backboxes, youve got space... (for smart switches, and dimmers, a 12mm box is no use) and the stupid design of decorative light fittings give no thought to loop in the ceiling roses. They like a simple one each of live, neutral and earth
Don’t know many domestic sparks that still 3 plaTe at the ceiling Light.
I always feed the switch now even for a pendant.
just so much easier to do all the connections in the switch
Something tells me a house rewire is a bit over the top for a trainee in their first year and with such a basic lack knowledge.
It does seem a bit worrying. Does the person who is paying for the rewire know that you are not yet trained to do it? Are you supposed to be doing this work alongside someone else?
I mentioned in an earlier post DPG the general public don't take much notice of experience or quals as long as the price is reasonable they are willing to take a punt.
If you don't know how to wire a lighting circuit then you aren't ready to be carrying out a rewire without an experienced electrician mentoring you.
Having someone check it over at the end isn't good enough, they need to be monitoring what you do all of the time you are working.
Electricity kills, very quickly, and very painfully, it is not something to just keep having a go at until you get it right.
RikoD91
Unfortunately the guys are spot with their judgement that you really shouldn't be working on your own at this stage and where is your mentor in all of this ?
You really should be seeking their advice and knowledge or that of the company you are working for if that is the case.
I appreciate we all have started somewhere doing bits on our own but not without proper supervision and a good backup support in times of difficulty.
Reply to Down/spot wiring in the UK Electrical Forum area at ElectriciansForums.net
Thank you all for your replies and suggestions. I will try to follow up on each one and find a suitable solution. many thanks all
3 core wouldn't, but 3 core and earth should I think. The live from the UH4 could feed both the brown and grey of the valve.
