downlight switching?? | Page 2 | on ElectriciansForums
Discuss downlight switching?? in the UK Electrical Forum area at ElectriciansForums.net
M
markbaldwin
hi peeps, im installing 12 downlights in a kitchen, im ok with the wiring of the down lights, but im having trouble working out how to wire from the downlight to the switch!! im running 2circuits, do i need 3core+cpc or 4core please help somone!!
Coming from another trainee I would say if you need to ask these kind of questions you are in over your head mate. What you have described has a very straight forward solution. Try knocking up a wiring diagram and see if it clicks. Also might be worth joining the Trainee section.
remeber what the wholesales say we dont give out electrical adivce..
but we are happy to sell you any thing you want and it will be cheaper to you than your average spark cause he has an account and you dont ha ha
all i,m saying is , if the o/p is installing some simple lighting he /she should know the simple basics
if i were a customer,i wouldn,t expect a boy to arrive at my house ,not knowing how to do the simpest work! its a recipie for disaster
Yep, kitchen is a Part P Special Location so a new lighting circuit is notifiable. If you aren't on a scheme, you need to notify your Building Control before you get started. As for your lighting circuit, you need to start from the beginning. What's the load? What correction factors for installation method? Once you've done your calcs, you'll know what size conductor and what rating you need for your switch/switches. Will your junctions be accessible for initial verification and IR in the future? There may be some parts that need to be MF connections. I'm surprised a trainee would say "I've got a kitchen, 12 downlighters and a switch and a load of 1mm, how do I wire it all together?"
Reply to downlight switching?? in the UK Electrical Forum area at ElectriciansForums.net
clearly a wiring or connection issue, lets see a picture of your connections
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
