Downlighter problem | on ElectriciansForums
Discuss Downlighter problem in the Australia area at ElectriciansForums.net
Sanke
Hi all
had a call last night from a potential customer He has 6 downlights in his bathroom & 3 have stopped working From his description of the two boxes on the loft I assume they are wired 3 lights to one transformer and one transformer has packed up As a rule what would you recommend 1) replace the existing transformer or 2) rewire so that each light has its own transformer ??
First question really as he now as 3 lights out because they seem to be on a single transformer he as called you in as it's an inconvinience. So how much of an inconvinience is it to him?
So really a better design for him would be to have each light with it's own transformer, but then you got to weigh up the costs of that. Give him the option, a like for like repacement for the tranny that controls the 3 lights, and then a cost for individual.
seems to me, starting up on full with GU10s is similar to tungsten. if it catches the peak of the supply sine wave, that's when they pop.
you mean soft-start dimmer
ahhh -those 3 20watts to 1 60va trafo shouldn't be allowed
they always get changed after to 50watt bulbs anyway
Reply to Downlighter problem in the Australia area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
An extra joint box isn’t a massive issue… use a wago box, with proper wagos. Nice and small will fit up through downlight hole. Wago box should...
