Downlighter question
Greetings.
A friend of mine wants downighters in the kitchen.
His kitchen ceiling is plasterboard with tongue and groove wooden panneling on top.
You kow the sort of thing, he wanted to make it look like a ships cabin so put thin battens on the plasterboard then stained tongue and groove wooden boards on top of those.
The effect is that he has a wooden ceiling.
The trouble is if I try to fit downlighters I don't think they will be long enough to go through the wooden ceiling and through the plasterboard, I think the springs that anchor the downlighters will not make it all the way through.
So my question is does anyone know where I can get extra long downlighters that can be put through a ceiling that is thicker than just plasterboard.
Cheers.
Best practice would be to bring existing T+E into J 501 then a length of 1mm or 1.5mm heat resistant flex to feed the downlight. This way if the flex touches the downlight the heat won't damage it, also each downlight will only have 1 cable entering the connection block which is the way it was designed.
I have to wait until later today ... my sister has gone SHOPPING!!! lol women !!! not to worry .. hopefully she will cook a nice meal after its all done:p
if you are adding cable, you must use silly (sorry, new) colours. if existing cable will do no reason to replace it
thats why i us the J501 then the loads evenly distributed,loads across a 16 amp jb not a 5 amp terminal block like it is on the down lighters ,as has been said Heat res flex from jb to down light save so much time in the long run no more struggling ,thats a thought why is terminal block still rated at 5 15 and 30 amp when all the protective devices are 6 16 and 32 amp and othe sizes ive not mentioned
La Poste,
Amp David,
TrueNAS JBOD Storage Server
