Hopefully some of you more experienced people can assist. One lighting Cct with 12 Downlighters off the same RCD functioned well for 5 years. Cct now trips when power applied, It was after about circa 5 minutes before it tripped. Now it is off without any reset.
What i did do.... I have isolated each lamp out of the Cct (G10), and tried to understand which position was causing the CCt to trip. No joy....... Changed each lamp and also left disconnected to try and remove the lamp from being the problem. I thought maybe defective RCD, but i don't think so..... Possible rodent problem in the ceiling..........Don't want to get seduced by this this as taking the ceiling down will be problematic. Any Advice appreciated!!
