downlighters | Page 2 | on ElectriciansForums
Discuss downlighters in the UK Electrical Forum area at ElectriciansForums.net
davek
Hi all
I have been given a electrical installation job of a builder who's electrician has let him down so slightly stuck on price and layout etc as already quoted. this ia a dormer bungalow so the roof space it pitches and has 6" timbers roof spars and insulated with 100mm insulation. now I need fit down lights in all rooms including bathroom with a head height at top of pitch 1.9m. I have seen some light by Sylvania which are listed as ultra compact also was looking at using led and suggestions recommendation welcome
Regards
Dave
I would only consider fitting LED 240V ones (I no longer install halogens, now that LEDs are reasonably priced).
that's the way I roll, small cost/small effort/small heat/small cable/etc etc. its the way lighting is going and it will not turn back, it is only going to get better. LED is the way forward. That's the way I see it and I'm sticking to it.
I did not do the quote, previous electrician did but had let him down on start date so asked if I wanted the job. just looking for suitable solutions on which lights would suit best. and ppl thoughts on using the back of light switch as junction box.
Absolutely no problem at all - I always do this with 2 way switching (upstairs/downstairs), wall lights, porch light etc etc
hi hawk one of the reason I ask this was there will be no access to any junction box one ceiling goes in so though much better to use wago connecters in switch back box for testing etc, also need connect a fan to one of these but think I have a solution to the fuse issue most go on about
I also have no problem with looping at the backbox - as far as I'm concerned it's the way forward for things like downlighters, wall lights and modern light fittings where they don't provide the facility to loop.
Older electricians will try to tell you it's 'bad practice' because in the olden days pendants always had a loop terminal.
On a side note I'd watch the price as well, and make sure you can do it for the price the builder wants, or tell him you're going to need more money. If the original electrician was going to make good money out of it he'd probably be doing it himself.
Well just to update first fix done. The said electrician who quoted rang him saying he could it a bit cheaper. But funny how he let him done four days in a row to but cu bak on wall as ceiling was lowered and was in the way. Even been paid for first fix happy days
Have you done a lighting design? This is what annoys me about so many electricians....they hazard a guess at how many lights they should install and where to fit them but without doing a proper design with proper software you don't have a clue.
I'd be very interested how you go about the fan issue, as I'm in the same boat. 3 amp fuse reqd for fan , time delay reqd and to wire lights in loop in loop out
My thoughts entirely.
Some people are just to lazy to dig out a few more mm to make the back box a jb, its neat, it's tidy, its easier to work on and with the aid of wago/line connectors its SAFE and easy to access and a mind blower to your d.i.y. type person they are gonna be thinking ' WTF is this ' .
Reply to downlighters in the UK Electrical Forum area at ElectriciansForums.net
