P
pete3
As part of a job i have been asked to fit 2 downlights in the soffits above each of two garage doors, the garage is detached and has a pitched tiled roof and is open (no ceiling or insulation) inside the roof above the soffits. The lights are to be connected to a timer.
I normally only fit fire rated downlights but was wondering whether this is required in this situation. I want to use low energy downlights if i can and would welcome your thoughts as you can get non fire rated low energy downlighters quite cheaply .
Thanks in advance.
Peter
Thanks in advance.
Peter
