downlights in extention | on ElectriciansForums
Discuss downlights in extention in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
leespark2009
hi building inspector has said that he does not want kingspan insulation to be cut in any shape or form so i am conserned with the downlights not being able to breathe is there any solutions to this install
Well insulated ceilings and the fad for mountains of red hot downlights is the cross we electricians have to bear unfortuately
Add to the suggestions ,if you use halogens make sure that the lamps have the aluminium skin that deflects the heat downwards
The hoods are supposed to cater for sufficient air flow I am told,but dont believe that for a minute
Agree with Des there, although i have to say, i wouldnt trust the client to replace lamps in the future with the correct type.
And they WILL replacing them fairly frequently, if they go with halogen.
hi everyone. tell the building inspector to put his face near the spots for as long as he can!!! then he will cut a breathing space himself.
Reply to downlights in extention in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Neutral and live
Hi does any one know or fitted ic integrated downlights suitable for rockwool .most say lay over insulation which is your standard glass wool...
