Downlights in lathe and mortar (replacing ceiling) | Page 2 | on ElectriciansForums
Discuss Downlights in lathe and mortar (replacing ceiling) in the Australia area at ElectriciansForums.net
G
GStueyXR
I recently done a job fitting downlight in lathe and mortar. I pre-warned the customer of the perils of doing this and the possible damage.
Anyway, cut a long story short, the holes I drilled have since cracked along the lathes and the customer has rang me to ask if I would carry out remedials... No problem, I want her to be happy. So, I have offered to put in a new cladded ceiling and refit downlights for half my normal daily rate. She is pleased with this...
Just need clarification of the best approach to this:
The job is an upstairs bathroom, I want to knock out all the old lathe and use existing joists to batten and fit cladding to. Is there a better approach to this ? Cladding is MDF.
Be careful son,ive worked in asbestos infected area for years,seen a couple of geezers peg outick it catches you,when youre older and weaker,board over,least disturbance....the better
Reply to Downlights in lathe and mortar (replacing ceiling) in the Australia area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
