Downlights | Page 2 | on ElectriciansForums
Discuss Downlights in the UK Electrical Forum area at ElectriciansForums.net
A
Adie
Hello i am in the process of fitting three downlights but there is no earth connection on the lamps,i have run the switched live neutral and earth into a junction box in the loft and than fed x3 1.5mm twin earth to each lamp but not sure if it is alright to terminate the earth wires in choc box at each lamp or do all the earths need to be joined together.
Reply to Downlights in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
