Discuss DP ISOLATION SWITCH. in the UK Electrical Forum area at ElectriciansForums.net
Sounds about right.
Extra PPE and training required to pull the main fuse, which regular electricians never ever do.
Then the testing afterwards, putting the fuse back, even riskier. Resealing fuse, paperwork.
Damn. Smileys still don’t work.
How do I convey errant sarcasm without smileys.
Didn't 'green stuff' used to refer to pound notes............Some suppliers do not charge for an isolator, maybe swap supplier to one who does not charge
There is also a scheme where the DNO will upgrade a supply for free for green stuff- and you will get a free isolator as part of the works
.......like fingers and toes used to be in Glasgow.....pound notes are still green in Scotland.... and are still legal tender.....
as are groats, guineas and bags of corn.....
Has to be a semi confident electrician who has permission to cut the seals and pull the fuse.Just speak to any semi competent electrician. Who can pop around at the end of the day and will do it for a far more reasonable price.
Reply to DP ISOLATION SWITCH. in the UK Electrical Forum area at ElectriciansForums.net
