DP ISOLATION SWITCH. | on ElectriciansForums
Discuss DP ISOLATION SWITCH. in the UK Electrical Forum area at ElectriciansForums.net
dogtag
Hi all just enquired with National Grid to get a DP isolation switch fitted in my outside meter box and was quoted a jaw dropping £220.00
Is this the norm now for safe isolation?
Sounds about right.
Extra PPE and training required to pull the main fuse, which regular electricians never ever do.
Then the testing afterwards, putting the fuse back, even riskier. Resealing fuse, paperwork.
Damn. Smileys still don’t work.
How do I convey errant sarcasm without smileys.
Sounds about right.
Some suppliers do not charge for an isolator, maybe swap supplier to one who does not charge
There is also a scheme where the DNO will upgrade a supply for free for green stuff- and you will get a free isolator as part of the works
Didn't 'green stuff' used to refer to pound notes............
Just speak to any semi competent electrician. Who can pop around at the end of the day and will do it for a far more reasonable price.
Has to be a semi confident electrician who has permission to cut the seals and pull the fuse.
There’s a reason there is a sticker that says “it is dangerous and an offence to work on this equipment”
Or words to that effect.
Reply to DP ISOLATION SWITCH. in the UK Electrical Forum area at ElectriciansForums.net
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
Thanks, that seem a better option. Thought I'd ask the question before asking for a installation quote.
