Drawing tools | on ElectriciansForums
Discuss Drawing tools in the Electrical Tools and Products area at ElectriciansForums.net
marc8
Essex
Hi all
sorry if this has already been covered does anyone know a product where I already have PDF drawing & want to overlay my designs on to the floor plans?
Most drawing files including AutoCad will convert to PDF....but converting PDF back into any other file is a problem. PDF is a secure file, hence the reason most quotes and invoices are sent in PDF to stop people editing or tampering with it.
all my designs are done on a smoke packet. can traced and overlay onto a beermat without too much trouble.
If your going into commercial, then the only way is AutoCad, which is layered for each section of install.....any other format is a waste of time
I'd agree with Tazz, the drawing will have been originally created in a different file format by a CAD program before it was converted to PDF for distribution to others. If you want to edit it or add a layer then firstly you need the drawing in the original file format and secondly you'll need the same program installed on your PC that created the drawing or maybe a similar CAD program that can deal natively with the particular file format.
I've always assumed that PDFs are distributed because PDF Reader is freely available, but has no editing functionality.
If you buy the full version, then they are editable.
I think most of us are, even with old dot matrix printers......but today we email everything, drawings, quotes and invoices....and no matter what software you use, having pdf printer or converter installed, prevents tampering.
Hi all
It depends how the original file was created: if it was created as a raster image it's easier to CAD from scratch - if Vector, then most CAD software will allow you to utilise the existing PDF as an underlay/baseplan. There are claims from some software companies that they can do all sorts of things but it just ends in a mess. You then spend much to long trying to join lines, patch holes, etc.
HTH
Billy
Reply to Drawing tools in the Electrical Tools and Products area at ElectriciansForums.net
I have tried pretty much every tool bag ,box, bucket ,case, caddy, tote organiser that you can imagine. and I have gone full circle and just gone...
Hi. Sorry if this is not allowed, but I'm on the hunt for my first electrical role. I've completed C&G level 1,2,3 currently doing my 18th...
