Drilled through a wire | Page 2 | on ElectriciansForums
Discuss Drilled through a wire in the UK Electrical Forum area at ElectriciansForums.net
Northants
Hi guys so I need some advice/help if possible, im a complete noob with electrical stuff so be nice lol, I was putting up a roller blind in my kitchen (drilling the pilot holes) and went through a wire that tripped out all the sockets at the back of the house, I then went to the fuse box and turned it back on and everything is working fine I.e all sockets etc are working without tripping out, what should I do please guys ??
If you insist on doing it yourself then make sure you read and understand the instructions fully. Examples of a MF junction box are the likes of this:
But only when used with certain matching terminals, which appear to be these range:
But you must read and follow the instructions fully. They might also specify a cable tie around the box to meet MF ratings, and you have to be competent and have the tools to strip the wire without damaging the conductor to the length specified for the terminals (sometimes they have a length indicator on the side of the terminal itself to help).
Also you will need some spare cable length to put that type in as it is not of the in-line style. Other folk might know of something that is easier to use, but without seeing the situation, etc, it is hard to tell.
One trick that can be done IF the socket the cable goes to is part of a RFC, no spurs come off of that socket, AND only one of the two cables together going down the wall has been damaged is to cut the damaged cable in the ceiling void, cut it off in the socket box, and join the 'live' end of the cut cable in the void to the other cable, so forming a spur off of the RFC.
Reading the first post again, "all the sockets at the back of the house" and "turned it back on" would tend to indicate the OP has RCD protection, or dare I say RCBO's, just an observation.
When are Quickwire going to make a 32A version of their connector??? It's been on the books for a long time.
Could you bury a quick wire terminal box in the wall ?
They have not produced them yet but as this would be one of the main things it could be used for then I think it would be a bit silly if they didn't design it so it could be fitted in a wall and plastered over.
Reply to Drilled through a wire in the UK Electrical Forum area at ElectriciansForums.net
Yup will do exactly that when I'm back down there. Thanks for the help
Which rcd is it? Is it one for everything, one for a few circuits?
