Driveway audible alert ideas | on ElectriciansForums
Discuss Driveway audible alert ideas in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
Has anyone got any recommendations for a wired driveway audible alert? A friend has a large drive and wants a PIR to turn brick lights on upon vehicles coming up the drive and also an audible alert at the same time.
I doubt there is a device that does both so probably a separate PIR and then something to alert them of a vehicle coming up the drive.
Any suggestions?
There used to be a simple lighting system with just this setup, a simple slider selected what function you wanted, lights, lights and beeper etc. the PIRs were 12V. Not sure if they are still made though. The unit fitted a standard double box.
Reply to Driveway audible alert ideas in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
Hi, did you decide to upgrade your test meter? If so, how are you finding it?
