Driveway audible alert ideas | Page 2 | on ElectriciansForums
Discuss Driveway audible alert ideas in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
Has anyone got any recommendations for a wired driveway audible alert? A friend has a large drive and wants a PIR to turn brick lights on upon vehicles coming up the drive and also an audible alert at the same time.
I doubt there is a device that does both so probably a separate PIR and then something to alert them of a vehicle coming up the drive.
Any suggestions?
So with these systems, they can switch a lighting load via a sensor and offer an audible signal within the property?
There is a controller which would go in the house, this has a buzzer in it which sounds every time a sensor detects movement.
The sapphire is single zone an dthe merald is two zone.
The PIRs are extra low voltage and usually wired in alarm cable, they can be split across three circuits in each zone (you can have multiple PIRs on each circuit)
Lux levels, walk test and number of detections required to activate the output of a zone are set from the controller.
Each zone has a relay output which I think is rated for 3kW
There is also a connection to link it to a burglar alarm to bring security lights on whem the alarm is triggered.
Done this recently with gate sensors, relay, psu and RF mains link. Other end of rf mains link was then plugged in the house 300 meters with another PSU, relay and piezo buzzer installed in an adaptable box. Gate sensors was installed at a height where foxes etc wouldn’t be detected but a human or vehicle would.
I need a little help With GJD 1500 pir system. There are two PIRs over 2 zones. When the floods are activated manually as soon as PIrs are activated on walk past the light go out and the panel flashes between zone 1 and 4 continually until it’s reset. Is the panel knackered. It is
Any suggestions?
Reply to Driveway audible alert ideas in the UK Electrical Forum area at ElectriciansForums.net
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
