Search the forum,
Discuss Driving LED Chip in the Lighting Forum area at ElectriciansForums.net
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips.
For some chips it is necessary to convert the 12v to 3 or 6v. Could you recommend some products that are easily available online?
If not, someone can advise me where to find some schematics?
One last thing, I bought a 12v RGB LED chip, on the Ebay page it was indicated to power it directly from the 12v transformer, but after a few minutes of operation the blue light stopped working. What could be the problem? Faulty Chip? I used a heatsink obviously.
Thanks.
Did you put heatsink compound on the LED when mounting it on the heatsink?
A 12V transformer delivers AC. A COB led runs on DC. Did you actually use a 'transformer' (ie AC supply), or was it an LED driver or PSU?
All LEDs need DC just saying :)
Thanks,
No, I didn't use thermal paste, but I didn't run the LED at full voltage, I used a controller and it wasn't running hot .
I used an LED Power supply 12 VDC, 15 W max 🙂
Reply to Driving LED Chip in the Lighting Forum area at ElectriciansForums.net
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
First time poster here seeking a little advice/confirmation I have spurred off to a fused switch and from there running two 2.5mm cables to the...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
Hello, We moved into our house 2 years ago and until recently the kitchen lights worked fine. The LED strip lights are on a dimmer switch, when...
