I think it started with the advent of digital testers. With analogue you could detect many anomalies in the circuit by the speed of the needle movement, the stabilty of the needle etc, what you were watching was an indicator that was directly connected to the circuit in test.
With digital there's always electronics sitting between the circuit and the result your seeing. The number displayed is an interpretation of what the tester is connected to plus there's a sampling rate to deal with so you can no longer actually see any small anomalies, they just get expressed as an error or 'noise'. This was the beginning of the deskilling of the tester and it's gone progressively worse from there and sooner or later it's going to boil down to 'go or no-go' testing where the person has no actual function other than to connect the leads.
Marvo you raise some good points which highlight how the choice of meter can be the difference between finding the fault or chasing your tail. There are times when a moving coil meter is far better than a digital meter although some of the high end digital meters are getting better with the bargraph displays as well as the digital reading.
The meter that Phil mentions comes with access to firmware updates as the Regs change so the meter can be flashed with the latest data so it always tests to the current regs looked to be a nice piece of kit but is it all needed. How would it sound in court if you were to give evidence and say it must be right the green light on the meter said so
I was challenged a few years ago by a guy because my MFT was a "16th edition meter" and we were now on the 17th edition so I asked him to tell me what the difference was and if my meter could be used to test an installation installed to the 15th edition got a very blank look and then had to explain exactly what an MFT is and no matter how it is labelled will still carry out the same tests needed to comply with the regs. There is a lot of kit out there that is sold because people can't grasp the basics of what an MFT is although similar things happened in the days of the separate meters
At another event I was at with Phil we got talking to the Fluke rep and having mentioned some of the test kit we own he seemed a bit surprised that sparks would own such high end test kit. Having said that he had a few IR thermometers and thermal imager's on display not exactly everyday test kit and not that cheap.
Back in my college days we were taught how to select the right test instrument based on it's input specification and the job in hand and having done that it was then how to understand and interpret the readings obtained this is where today's training lacks so much and where "driving the meter" is a lost skill but there is always an internet forum these day's that will always accept random questions. May be the next step will be test meters that can be viewed remotely over the internet by an experienced spark while there is a meter monkey on-site being guided by the spark
How many actually use all the functions of their MFT or even understand what some of the added / extra functions are for, reminds me of the BT engineer who came to fix my broadband pulls out his laptop and sets the data tests running I had a look at the live readings on screen and was chatting to him about them he admitted he didn't have a clue what it all meant all he needed to see was that 2 of the parameters were within a certain range the fact that I was using a similar tool on radio networks meant I knew more about what he was doing than he did
You can have the best test kit money buy but if you don't know how to use it or understand and interpret what it is telling you then you have wasted your money or alternatively you may be under educated in your chosen trade or just plainly in the wrong trade
