Drum Hanging Down in AEG L75670WD Washer Dryer | on ElectriciansForums
Discuss Drum Hanging Down in AEG L75670WD Washer Dryer in the Electrical Appliances Forum area at ElectriciansForums.net
London
The drum is hanging down. I googled the problem and its seemed that the bearing needed to be replacement. However, I am unable to find this part. Is this because its called something else in this model?
The whole drum assembly, including the outer tank, is held steady by shock absorbers at the bottom, which wear allowing the drum to shake about.
There are also springs at the top holding the drum assembly up - are they OK?
From personal experience, these things are not always the easiest to replace, and the sharp metal edges in the machine can bite you!
Click below on "functional parts":
Before buying anything make sure of model number etc.
Reply to Drum Hanging Down in AEG L75670WD Washer Dryer in the Electrical Appliances Forum area at ElectriciansForums.net
Hi, We’re having problems with our Bosch serie 6 washer/dryer. It’s about 6 years old. The model number is WVG30461GB/03. It has begun to stop...
By code the washing machine needs its own 20 amp single pole GFCI circuit, the dryer needs a 30 amp double pole breaker and using # 10 wire. Your...
