Dry Lining box For Double Socket Underneath in Wall | Page 2 | on ElectriciansForums
Discuss Dry Lining box For Double Socket Underneath in Wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think you need to ask, is the dry lining box is suitable for the environment?
I can see his concern where the box was exposed, albeit under a bath, but on the same wall where there is the possibility of water running into the box, if the bath is not sealed to the wall properly. He just didn't explain things quite that way in the OP - ref Post 9
It's for a socket in the adjacent room.
I know Pete, all I'm saying is that without seeing it that would be my concern. It might be for a socket in the next room but the box is below the bath. A dry lining box has no IP rating so I would want to know that water could not get into it it there was a leak.
If the bath leaks my first concern would be water getting into the lights dowstairs, but fair point if he is that worried, must be a right bodge job if you can see the box from under the bath, did the installer bash a hole right through onto the bathroom?
Dont see a problem myself if the socket is in an adjacent room, the socket itself is not in the bathroom.
If you are that worried screw a bit of plasterboard to the bathroom side of the wall
Reply to Dry Lining box For Double Socket Underneath in Wall in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
