OP
JONO22
48 mA on the Ramp test? I'm assuming that 30 mA RCD's are installed
shouldnt it be boing below 30mA?
Discuss dryer tripping rcd in the Electrical Appliances Forum area at ElectriciansForums.net
"I has exactly the same issue a few months back although my client was advised by other (non electrical people) that i had done something wrong and it was all my fault. I simply put her mind at rest by paying her a visit and doing a quick test (insulation resistance and continuity tester) to prove her dryer was at fault. I also put everything i could find and switched it on informing her that everything was on load and the rcd held but as soon as dryer was switched on trip. I then repeated this process with nothing switched on in the whole house and as soon as the dryer went on trip. She soon came to believe me it was the dryer
All the people telling her it was something i had done were very public about it ...kindly informing her on an open page on facebook!"
That will be "know it all geezers" who were trying to impress her. Sadly, they know squat! I hope she told them they were all wrong and none of them had won the biggest w***y competetition on this occasion!
The trouble I have is the customer is stating “it worked beforeyou changed my old death trap for a nicesafe C/U scenario”
I know and am able to pat test but as I as recently self-employedthat a pat tester is still on the shopping list
Just get an adapter to use with your meter for now. I regularly use one of these (don't remember paying this much for it though):The trouble I have is the customer is stating “it worked beforeyou changed my old death trap for a nicesafe C/U scenario”
If your 30 mA RCD is going out at 48 mA on a ramp test then there is something wrong with it.
Thanks orderd one todayJust get an adapter to use with your meter for now. I regularly use one of these (don't remember paying this much for it though):
Kewtech PAT Adapter/Adaptor 1
Will defiantly take this on board for the future thanksYes but you should have highlighted to them before you started that they can have faulty equipment in their house or even a neutral to earth fault and it would not be noticed with a fuse or circuit board but it will and can be picked up by a RCD safety board also I was called back to a job and I took my PAT tester with me to prove it was the iron causing the fault customer was well chuffed that the RCD picked up the fault before he had an accident
Reply to dryer tripping rcd in the Electrical Appliances Forum area at ElectriciansForums.net
