Dual colour warning labels | on ElectriciansForums
Discuss Dual colour warning labels in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
So do you stick them on CU? Are they necessary? Are they a waste of time and materials.
Cards on the table - I think we should boycott them completely!
I agree there is no need for them, however I usually fit them to maintain compliance. Never know which job may end up getting shown on your annual assessment.
Anyone who is altering a system that has mixed colours should have the knowledge and training to do so with competence. Knowledge of previous colour systems is part of being competent.
IF we stopped using lables, as much as they ARE annoying, would we not be contravening BS7671, our bible?
This is true but what purpose do most of them serve, I can see the need for voltage warning labels sometimes. My CU has an rcd notice but I can't remember the last time I pressed the button.
I can see the point of bonding labels, to try (in vain) in remind plumbers to leave them alone.
I can see the point of RCD test and frequency of inspection notices as they are aimed at the end user who may have limited technical knowledge.
I can see the point in dual supply/multiple isolation points labels for safety reasons.
Voltage labels are not required though in most LV situations.
Does anyone pay attention to rcd notices, yes the dual supply notice I agree. Voltage warning labels yes, but I agree only in limited instances on LV systems.
I don't get any of them. People who have no knowledge of electricity or related systems don't take a blind bit of notice of them, and people who work on the systems should know what they are doing without having labels to remind them. Waste of time and effort. Good way of demonstrating to an assessor that you have read the reg's though, even if the rest of the install is sh1te. Last time I got assessed he just tapped each of the labels on the CU, nodded and that was that, after a quick Zs test.
Well as anything goes for DIYers then we have to assume they may work on their own home system.
And they could be coloured blind so not notice the old pre harmonised colur difference. So I'd say yes. May as well stick it on just in case tgat highly unlikely occurrence should happen .
But what if they are blind? Should we be fitting braille notices as well?
Reply to Dual colour warning labels in the UK Electrical Forum area at ElectriciansForums.net
No it is not implying it is safe, it is stating what the recommended date for the next inspection is. The next inspection date sticker doesn't...
davesparks
My older card has it but my newer card doesn’t
