I have a customer who has a dual immersion water heater. The bottom element is on off peak and the top is boost on normal. The customer has PV and wants to use his PV output to heat the water, but only in the summer.
I need to come up with a method for the customer to easily swap the off peak from the bottom to top immersion heaters and the peak from the top to the bottom.
The system is as follows
Airing cupboard
2 supplies
One RCD protected b16 peaks
One non RCD protected supply bs3036 fed from contactor operated by economy 7 switch
Winter
bottom immersion fed by off peak - normally on
top immersion fed by peak - normally off
summer
bottom immersion fed by peak - controlled by throttling mechanism according to PV output
top immersion fed by off peak - normally off
I was thinking that I could use a 4 pole changeover switch normally used by a generator or do I need to use some contractors. Obviously I'm going to have to keep the neutrals separate otherwise I'm going to get RCD trips.
Any advice would be much appreciated.
Airing cupboard
2 supplies
Winter
summer
