Dual rcd board | Page 2 | on ElectriciansForums
Discuss Dual rcd board in the UK Electrical Forum area at ElectriciansForums.net
North east
Just looked at a board in a friends house next door to me . I have same board with only one rcd fitted . His has two fitted but I think the extra one has been added at a later date as rcd looks newer than everything else so his is now dual rcd board and everything is covered by rcd . I know you can buy a blank board and put what you want in to suit but can you “ convert “ a single rcd board to a dual . All looks fine but would manufacturers warranty be invalid or anything like that . Tia
Reply to Dual rcd board in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
Thanks Westward, and that last paragraph with the Note about no characteristic marking is exactly what I needed to see.
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
4K
