J
JimmyDaWolf
Hi
We have recently supplied a new installation for a customer of ours in an extended industrial unit. It was gutted and installed from scratch.
There is a transformer in the main sub room that feeds some really old switch-gear with a main incoming switch with 4 outgoing cubicles. We have used two of these outgoing cubicles to supply the another unit separate from this one., 1 supplies the existing half of the unit with a 90mm swa and the other supplies the new extension side of the unit with a 240mm swa. These both run into the same sub mains room and have into 2 separate main incomers. a 200A Switch and a 530A switch. although these units are bolted together via the Earth bar they are both separate. the 200A Has 2 ways, one of which feeds a DB in the old part of the unit used for storage only. The 530A feeds a board in the new half of the unit and also feed the machinery in that half.
Transformer ------Main incomer-Way 1--------530A Incomer----3 ways out to Unit 1
Way 2--------200A Incomer----2 ways out to unit 2
So out of these what would i record as the Primary supply OPD, Main Switch Or Circuit Breaker?
Main OPD for each Sub mains? Main OPD for the DB's in the units.
Im struggling on how to put all this into PIR Form. I have all the qualifications i just really struggle with these forms some times. any form for that matter.It doesn't seem like i get all this information onto the forms.
Any help would be appreciated.
