Hi all, first time post on here so hope you can help. We are wiring a small bar/bistro which has a self contained flat above owned by the same bloke. However the flat is off a totally separate supply to the bistro (separate cabinet around the back) what is the score with running different supplies in the same floor space? I’m guessing a lot of this must go on in flats etc but not sure on the NIC’s take on it. Thanks, jas
