dual tracker for a small 2.14 kw system | on ElectriciansForums
Discuss dual tracker for a small 2.14 kw system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
judgeelectrical
Does anyone know of the smallest dual tracker invertor out there. I have a cusyomer who has the panels already and wants an invertor for 9 240 watt phono solar panels which will be split 5 and 4 and have different angles of tilt for each set. Is it a case of 2 small invertors, or is there a small dual tracker out there. i have looked at the power one stuff, but it seems only 5 panels will meet the min voltage. Any advice would be helpfull, or anyone who has done this before
Thanks for the recomendations guys, not really considered the micro invertors, but will have a gander at the solar edge stuff and re look at the pvi3.0.
I agree not ideal Biggs. As I have said before I would normally undersize inverter at around the 4kW point. But for this it seemed an economical way of doing it and an efficient TL just off best operating point will probably be better than x2 smaller inverters. I'll see if I can dig out the Power One efficiency curve.
Here are the graphs I was thinking of. The efficiency one does not show exactly the operating point we would be thinking of. Wearing my cynical hat that might be because it is not a very efficient operating point! It also means looking at the second graph that you would be working in an output limiited area of the curve. On reflection there might be better inverters for this application unless the helpline could give me an accurate efficiency figure.
[ElectriciansForums.net] dual tracker for a small 2.14 kw system[ElectriciansForums.net] dual tracker for a small 2.14 kw system
That efficiency curve is interesting. Again, this seems contrary to what I've heard before.
I can only assume the guy at SMA misunderstood my question or I misunderstood his answer.
StecaGrid 2000+ has two trackers and a nice low start voltage, 80V. There might be a very slight loss from the 5-panel string as max DC power is quoted at 1075W per tracker. STECA PV grid connected
Reply to dual tracker for a small 2.14 kw system in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I'd really love to see these schemes taken out of the hands of devolved governments as they're generally very different from one part of the UK to...
nicebutdim
N
I am living in the north of Thailand outside of the big city. That means in the rainy season we have multiple times per week power outages...
