Dumb question incoming | on ElectriciansForums
Discuss Dumb question incoming in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Evening guys.
I am sorry if this has been asked or if it is stupid.
I understand the logic of not fusing the neutral, but what was the logic for fusing it in the first place?
Kind regards,
Chris
Evening guys.
Kind regards,
Chris
That's something I've been wanting to ask for a long time but was never brave enough!
Thanks for asking! ;)
think it's leftover from the old days of D.C. not sure why though. someone must have thought it a good idea at the time.
maybe because it them days the DNOs didn't possess any form of polarity tester and were covering reverse polarity.
Given the fact you were using wooden wheels Tel, I am shocked to see you imply that DC was past tense for you and more so that you don't know!!
I will leave the smart --- reply to Geordie :grin:
don't hold your breath. up there they're still on DC,
Think about it, if your changing a lamp in a edison screw light fitting and the neutral has a blown fuse, the lamp may appear to be off but the possibility of a belt very possible, also it is possible an earth and neutral connected together yes, if so the fuse being blown in a neutral will not stop a connection to earth and an appliance working will it?
Reply to Dumb question incoming in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
I would hazard a guess your electrician may be able to contact your DNO and have the switch swapped to a MFS very quickly..
