Earh loop problem | Page 2 | on ElectriciansForums
Discuss Earh loop problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
it is a tns system and i tested at the db on just the main earth and the sheath of the supply and reading was the same 0.75ohm. the only odd thing about it was there was some damage to the sheath of the supply and the original earth clamp had signs of arcing perhaps a previous fault and a loose clamp but still came up with a ok reading with a new clamp.
asked several electricians i used to work with and non of them could give me answer as what could be causing the high reading.[/QUOT
Who fitted the new clamp and what sort did they fit????
Reply to Earh loop problem in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
Thanks all for the suggestions! Customer doesn't store anything else in the cupboard with the tank, not even towels or sheets. Heatrae stat is...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
