P
philsheriton
re sited and changed aconsumer unit from an old wylex re wireable to a new split board with mcbs and an rccb protecting part of the buzbar all transfered ok except shower (8.5kw triton) on a 40amp breaker powered up fine pul swich on shower working ok but try to increase load ie turn up the shower and the rccd trips not the mcb sounds like earth leakage ? asuming the cables are installed in the correct neutrals and earths on the board need advice urgent it was fine on the old system however but the new one is far more sensitive what can i do any idea's Phil sheriton
