Earth bond clamp for oil pipe | Page 2 | on ElectriciansForums
Discuss Earth bond clamp for oil pipe in the UK Electrical Forum area at ElectriciansForums.net
dnjr
South coast
Dear All
Got a board change to do where there is an incoming oil pipe.
Plastic tank with PVC covered copper pipe most of the way. Comes inside and its just copper coming up through the floor. Did an IR test and got 0.00 so it needs bonding ( as I understand it its got to be under 0.02 to not need bonding)
Problem is the pipe is only about 8 or 9 mm dia. and i cant find a small enough clamp.
Someone suggested either a P clip or strap banding but they dont seem very professional. what are people using please
cheers
dnjr
Wholesaler came up with this
It's an earth bond link made by Tamlex for trunking bent round. Giving it a go
[ElectriciansForums.net] Earth bond clamp for oil pipe
I still di t get why an earth clamp wont fit? Take a pic im intrigued, ps dont forget to affix bonding label to your clamp
Hi Suffolk
Standard clamps I have seen either have a sort of box section bit in the clamp which would wobble about on top of the pipe or have a 'U' shaped but with the clamp which is too big and straddles the pipe and band can't go tight enough. Honest. I've tried. ...
1.do it when there's no oil in the pipe
2. clamp heat sinks on pipe to prevent the oil overheating. it needs to vaporise to ignite.
The oil will not ignite unless it reaches temperature where it vaporizes allowing it to mix with oxygen, liquids do not burn it will however act as a heat sink removing the temperature from the pipe.
That's right, these fuels won't burn without air. It's my understanding the vapour point of heating oil is significantly below the melting point of solder. Again, just saying ...
The flash point of heating oil depending on the type will be approximately half 200°C.
Reply to Earth bond clamp for oil pipe in the UK Electrical Forum area at ElectriciansForums.net
If there's no main switch on the CU, then the RCD is doubling up as the main switch and everything is protected by it. If there is a main switch...
