Earth Bonding | on ElectriciansForums
Discuss Earth Bonding in the Australia area at ElectriciansForums.net
A
Amazed
I have just purchased a flat that had a new consumer unit installed in March 08. However I was surprised to find that there is no earth bonding in the bathroom even though it has an electric shower. The only earth bonding I can find is to the incoming gas pipe and to the cold water pipe at the washing machine. Furthermore, the shower has no pull switch in the bathroom, only a wall mounted switch in the airing cupboard in the hall.Should I call in an electrician or is this ok. I have all the certificates for the work done so I suppose it should be to the necessary standard.Any help appreciated.
Hi and welcome to the forum:DCan't see a problem with that
It is a split load box. RCD protection to sockets and shower, non RCD to cooker and lighting. Furthermore, I have had all sorts of conflicting info from electricians i have spoke to. I have changed the old cooker for a new gas hob and electric oven. I want to fit a double socket in the adjacent unit to plug my gas hob(electric for ignition only) and electric oven into. I then need a supply spurred off this to power my cooker hood.I have been told that this cannot be done as you cannot fit sockets in units. This particular electrician told me to cut the back panel of the unit so he can attach it to the wall. Is there any other way and will it need 6mm cable to the extractor.
Reply to Earth Bonding in the Australia area at ElectriciansForums.net
I am living in the north of Thailand where the grid is very unreliable (rainy season outages multiple times per week or once a full week). I...
B
Using an AAV for washing machine waste trap Hi We have a small utility cupboard for a washing machine with a standard washing machine waste kit...
benawhile
B
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
