Hello
Had to install a new towel rad in bathroom. Replacement narrower than original so had to adjust 10mm pipework. On breaking into stud wall I found that the green/yellow earth wire clamped to the rad pipe was chopped off and merely plastered over in the stud wall. Property 20 yrs old and clearly the way the builders electrician had left it. Bathroom floor tiled. No pipework to extend/reattach loose end to without lifting chipboard in adjoining bedroom and breaking into back of stud wall from there.
I can’t imagine I’m the first to experience this issue but what is the usual course of action?
