Out of curiousity what is the formula for calculating length of run? Cheers
Table I1 in the On-Site Guide (p190 in the yellow one) gives resistance per metre (for a single conductor, e.g. end-to-end on a ring) and (R1+R2)/metre (if using method 1 for continuity of protective conductors).
The row that says "1.5" then a "-" is the resistance per metre of your cpc: 12.1mΩ
The row that says "2.5" then a "-" is the resistance per metre of your live conductors: 7.41mΩ
To work out the theoretical length of the cable (based only on measured resistance) you take your measured resistance and divide by one of those numbers. You can either convert your measured resistance from Ω to mΩ, or convert the above numbers from mΩ to Ω, or just use both numbers "as is" and multiply the answer by 1000.
So: ( 0.8 / 7.41) x 1000 = 108m (for your L and N end-to-end),
and: ( 0.6 / 12.1) x 1000 = 49.6m (for your cpc)
If 108m seems a bit long for your RFC, then a couple of poor connections on your live conductors is more likely.
If 50m seems a bit short for your RFC, then a parallel path on your cpc is more likely. This might be supplementary bonding, two water heaters / boiler connection, or even something bizarre like a switched FCU that forms a link between the two legs of the RFC about half way round when switched on (but not when switched off), and will always form a link for the cpc (I have seen a level 2 student terminate a S-FCU like this, bless!).
Handy reference for resistance/m:
1.0mm: 18.1 mΩ/m
1.5mm: 12.1 mΩ/m
2.5mm: 7.41 mΩ/m
4.0mm: 4.61 mΩ/m
6.0mm: 3.08 mΩ/m
10mm: 1.83 mΩ/m <--- main equipotential bonding conductors (usually)
16mm: 1.15 mΩ/m <--- earthing conductor (often)
25mm: 0.727 mΩ/m
Handy reference for (R1+R2)/m
1.0+1.0mm: 36.2 mΩ/m <--- older lighting radials (and sometimes strappers, e.g. with 3x1+1mm)
1.5+1.0mm: 30.2 mΩ/m <--- standard lighting radials
2.5+1.5mm: 19.51 mΩ/m <--- standard socket radial (protected by 20A OCPD)
4.0+1.5mm: 16.71 mΩ/m <--- standard socket radial (protected by 30A or 32A OCPD)
6.0+2.5mm: 10.49 mΩ/m
10+4.0mm: 6.44 mΩ/m
