Earth Electrode Query | Page 2 | on ElectriciansForums
Discuss Earth Electrode Query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
they are cheaper at the borg on line shop. they come ready integrated as a collective combination of rods.
It would serve no useful purpose spacing rods at these sort of spacings on a multi rod installation... 1.5X the driven rod depth is ample.
One, it's not the depth, it's the length of the rod which determines the size of the hemisphere, two, the 2.2 is the correct spacing, at 1.5 there will be overlapping of the hemisphere's. Come on E54 get current lol
Think you'll find that the formula is based on the buried depth (length) of a given rod or coupled rods!!
I have no idea where you get the 2.2 X L as being the standard distance for general soil conditions ...it's certainly not a figure that i've seen before!!!! lol!!
The only time you would think about going to 2X or more, would be in the most favourable soil conditions where the zone of influence of a given rod would/could be enhanced, or between separately derived earthing systems. If your talking about an earth ring around a building, yes it would be prudent to go with greater distances between earth electrodes (rods), but this is mainly to cut down on overall costs, rather than for over lapping purposes/measures. Same goes for lightning protection systems where it's not unusual to see 10 metres between 3m earth electrodes (rods).
I'm used to using 3m x 3/4'' copper bonded rods, and generally in ground field installations. I have never had a distance between the rods that exceeded 5m and can assure you that we have never seen any instances during testing of the individual rods (or between grids) of overlapping zones of influence, ...not One!! Were talking here in the 10's of 10's rods, making up these ground fields and being set out in integrating grids....
So i'll Stick with what i have previously stated and what i know, that 1.5X the buried depth (length) of the rod is ample for general soil conditions... I'm not saying there is anything wrong with greater distances between rods, ..just that they would generally serve no useful purpose...
Reply to Earth Electrode Query in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
