J
jay123
hello
Ive removed a dozen 'dead' cables from behind trunking, split the lighting earth from the radial earth, verified r1,rn,r2 back to dis-board yet when I pull the earth at the disboard it floats up to 117volts ???
can't believe the 20m of shared conduit run would cause this.
just can't understand why the earth floats high when measured at (diconnected) distribution board.
radial circuit, 10 sockets, problem persists even when only 1st socket of circuit is connected ie most of [FONT=Helvetica, Arial, sans-serif]radial is eliminated f[/FONT]rom equation.
when earth is pulled and circuit is energised it sparks on disboard earth bar.
help
help
