earth is floating to 117v when disconnected at distrution board - help | Page 2 | on ElectriciansForums
Discuss earth is floating to 117v when disconnected at distrution board - help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Confirm you actually have 117V by measuring with an analogue multimeter. Is this installation domestic or commercial/industrial, ie are we talking PVC conduit/trunking or metallic??
What you really need to fault find your problem is this kiddie. Every spark should now own a leakage tester, i can't see how any of you without one can find/confirm source of leakage problems...
TM-EL9809 High Resolution AC Earth Leakage Clamp Meter
Marvo was a little out on his £30 costing, but this unit is the same Di log unit rebadged, well worth the money, and you get a 5% discount from the forum sponsor to boot!! lol!!
Reply to earth is floating to 117v when disconnected at distrution board - help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Why go to the trouble of adding another cable, which I assume would follow the same route as the other ?. Why not upgrade it. It was to try to...
