Earth Leakage Clamp Meter | Page 4 | on ElectriciansForums
Discuss Earth Leakage Clamp Meter in the Electrical Tools and Products area at ElectriciansForums.net
my cheapo unit is a 1mA resolution. good enough for those awkward leakages that i can't detect by touch and smell.
What unit do you have?
I bought a UNi-T 210E and that has a 1mA resolution, but I think the accuracy is around +/- 5mA...
UNI-T also do UT211B which has a resolution of .1mA and a low range of 600mA with a max range of 60A which all seems quite good for a ÂŁ60 tester.
The only down side I can see is that they can't be adjusted/calibrated as the more expensive meters can...
I sent Test Meter an email, who kindly replied with a code for few more pounds off a Megger unit. :)
Prove it... What was the code??... :tearsofjoy::tearsofjoy:
My fluke 368 is two weeks or so away. I got the EU version.
Just to let you know....
FLUKE IS BETTER THAN MEGGER!!
Especially for their voltsticks! Always used the Flukes but thought I would try the Megger version. Piece of junk it is, doesn't slide easily into toolbag or pocket with its daft shape, but worst of all it is oversensitive in the extreme. Picks up voltage occasionally with the main dp switch off...! As a tool to give a rough idea of voltage being present or not it fails badly...
My Fluke elcm doesn't miss a beat either, but I do still love Megger mfts..
Reply to Earth Leakage Clamp Meter in the Electrical Tools and Products area at ElectriciansForums.net
