- Joined
- Apr 15, 2011
- Messages
- 469
- Reaction score
- 152
Hi Guys, Have a problem with a Omron Switch mode power supply & Omron Control Relay Which is only switching a 3phase mixer paddle to stir liquid while in the heating process. The control gear is fed from a single phase supply plugged into a RCD protected socket. The Rcd trips within 9ms @ X1.
I have found that with the cable supply plugged in & not switched on I am getting 45mA of Earth Leakage. The Whole Processing Plant is Stainless Steel Tanks on a gantry. I am assuming that the circuit supplying the rcd has earth leakage & dumping to ground via the supply cable.
Any advice would be much appreciated.Thanks In advance.
