nedwards9820
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I am planning to cut the plug off and hardwire it to a switched fused spur. There is a curious electrical isolation connection that is supposed to be fitted to the hot water outlet. The installation video shows metal-braided water hoses being fitted to the cold and hot water connections. What is the isolator supposed to be doing?
Do you think it is preventing electro-galvanaic processes within the heater? Maybe for properties that have copper water pipes?
As the heater contains a stainless steel heating tank with metallic pipe connections, I can't see that the electrical isolation device on just one side will actually actually achieve any electrical isolation.
Is this a misplaced attempt at double isolation? Maybe the water connections are supposed to be made with non-metalic hoses? Stills from the installation video ( assembly vedio.mp4 - https://we.tl/t-MTnshSodkE ) are attached.
The manual says to ensure you have a professional electrician wire the heater to a 110V supply.![Wink ;) ;)](https://cdn.jsdelivr.net/gh/twitter/twemoji@14.0.2/assets/72x72/1f609.png)
