Earth leakage measurement
Meters that measure current using probes on leads require you to break the circuit and put the meter across the break. The meter will then be in series with the circuit being measured. This is usually very awkward if not impossible unless you are in lab conditions, hence the popularity of clamp meters for measuring current in everyday situations.
about £100 + vat. but if you do a lot of fault finding one of these is a must. i'm saving up. if anyone's got one going cheap second hand, i want one!!!
not much work on at the moment mate, bad time of year anyway. going to have to do some leaflets methinks.
aye serious, get it going telectricx il come work for you in 2 years time , be no slackin then
and il have look at post 8 now engineer thanks hunni
so just ac setting on a normal clamp meter on earth conductor, so the leakage tester is just another toy
A "normal" clamp meter will probably not have a fine enough resolution for earth leakage. If you think about what you're measuring it's usually the amount of current necessary to make a rcd/rcbo trip (very often around the 2x milliamp area ... even though they're rated at 30ma most will trip less than that). Remember right tool for the right job.
my 1 gallon whisky bottle needs a lot more coinsin it to buy another meter. just booked my 1552 in for calibration, thats £57.50.
You could probably do the calibration check yourself telectrix. Once it's been done get yourself a set of resistors appropriate values for your meter and use them as a benchmark for your calibrated meter. You can then check the readings on the meter against your benchmark. You will still need to send it in to get it adjusted (and will of course need to keep the necessary records) but only if it needs adjusting.
Oh you'll need to keep the records of the check as well of course.
yeah, i gojng to get one of those calcards. the 1552 was bought out of calibration, but checked it against a mate's calibrated mft and the readfings were nearly all identical. got assess ment coming up soon though, so got to get a cert.
hoover,
telectrix,
