Earth leakage on sockets | on ElectriciansForums
Discuss Earth leakage on sockets in the Talk Electrician area at ElectriciansForums.net
manchester
This has messed my head up so much I’m not sure I can even explain it properly but hopefully someone out there may give me ideas of what to do next…
Had a call out to a house today with the owner (polish if it has any relevancy) saying he was getting small shocks off taps & was getting a reading on his socket tester which showed green green red which doesn’t have an explanation on the tester and the RCD was not tripping.
It is an 8 circuit setup over duel RCD. The owner said he had different mcbs set up for different sockets (1 for tv, 1 for comp room, 1 for lounge etc).
Although the ccu had only been in a year it had NO labelling (inc circuits), no installation certificate etc…
I tested the socket ring (32A) end to end r1, r2 & rn but with no continuity suggesting it was actually 2 radials.
I tested continuity (all unplugged) and found r1 & rn = 10 ohms, rn-r2 = 0.56 ohms, r1-r2 <999.
Checked sockets (which I had to break two of cos they were tiled in with broken screws) & found one had L/N reversed.
Found a socket with four spurs off it (to boiler switch, lounge socket*, upstairs, utility cupboard). The boiler switch had three spurs off it (to boiler, utility lights, upstairs socket). * which then had a spur to a lounge wall light
I did a alternative IR test on the boiler which failed (I believe due to the bonding becoming live)
I isolated the ‘faulty’ radial at ccu at L,N & E and tested the other sockets which showed the earth still live (50V). I isolated each & every circuit at a time at the mcbs but still got 50V on the other sockets. There was 50V getting back to the earth so I removed each cpc one at a time but still got 50V going back to the socket. Did the same with neutral & got the same result.
Alas I couldn’t think clearly any more & needed to eat so have left it for now.
I have 4 ideas at the moment:
1) two way landing lights using the cpc as live conductor. But would this affect the neutral?
2) another terminal wired with wrong polarity. But this wouldn’t make the cpc live? 3) A big screw going through the L/N & E
4) Water infiltration under the floor into a junction box.
Anyone come across anything similar with any tips and can save me having to test every circuit individually? It’ll take me ages just to label which circuit is which – especially as they seem to have this fault linking most of them together.
p.s. I replaced the RCD the ‘ring’ was on which wasn’t tripping, even at the button.
When I went to test the RCD I kept getting CON on my Megger (“wrong connection to instrument”)
If he's getting shocks there's 2 faults. Firstly there's something floating outside the equipotential zone and not bonded, secondly there's probably an IR fault causing an earth leakage current assuming it's not functional leakage.
These test results make no sense.
I'd suggest you sort out the circuit first by either reestablishing the ring or making it into 2x radials on separate MCB's. Once you've done this then retest.
Sounds like you're going to be busy.
I don't understand how bonding can become live. Fix the bonding.
Instead of chasing phantom voltages on live circuits and disconnecting CPC's which is probably going to result in someone getting a whack, rather concentrate on each circuit one by one, do the dead tests and fix the issues they show up.
You're running yourself around in circles.
No, there's no quick way out. Do the dead tests and fix the issues on each circuit one by one. Check and test the bonding.
Hi dude,Pretty well covered^,have you any results for test prior to above? Incomer type,earth arrangement etc?
You may have got a bit ahead of yourself...a methodical approach is required,when faced with a myriad of issues,such as described.
Not jibing you,but you mentioned changing an RCD,but did not list the testing on that component.
The customers' nationality is of no consequence whatsoever. His possession and use of a suck-it-an-see,might be...:smartass:
Thanks for your input guys.
To try and answer your points:
Davesparks, I tested with a voltage tester & also my megger.
Marvo,
P1) Quite possible
P2) I did separate the ‘ring’ onto 2x 20A mcbs & no, the readings made no sense (but nothing in that installation did).
P3) I’m already too busy, ergo me working on a Sunday at 5pm in the dark lol.
P4) I’m thinking a cpc has become live & working back to the ccu & bonding (then tracing back to the boiler?)
P5,6) I, of course, put the cpcs back ensuring no one was able to interfere while I tested. And you are right. I told him I would have to test each circuit one at a time (which will take a while, especially as there are so many radials & downlights and nothing is labelled)
Peg,
It’s tncs, 1361.
I tried to do it methodically but was coming across so many issues it kept taking me back to square one (and into the darkness – god, I hate winter!).
I tried doing an RCD trip test ½ & 1x but my megger was coming up ‘con’ which is wrong connection to instrument. I tried doing the RCD test button which did nothing so I swapped the RCDs around resulting in the test button now working (but not on the supposedly faulty one still - which I have swapped for a spare).
Nothing against poles, I just got the feeling his mate (if not him) had done the ccu & wondered if they had a habit of doing certain practices that might help explain this.
I guess it's back to square one testing each circuit. If he had this done on the cheap he's going to regret it now.
Just to add. He has two 2.5mm radials, one to his tv & one to his computer upstairs. Both on 32A.
Just something else I had to deal with ontop of the earth fault, the socket wired with reverse polarity, the faulty RCD, sockets with broken screws and glued in, 9 unmarked circuit (6 of which are sockets) & the multiple spurs off 1g sockets :dizzy2:
Incidentally, I tried identifying some circuits with a circuit finder but it was indicating several circuits including lights. Any ideas why this may be?
cheers again
I think you are getting carried away with it. You are there to find out why the owner is getting shocks. That will mean verifying earth continuity on each circuit and then IR testing each circuit,earthing and bonding etc. All the other issues you come across such as broken rings etc are incidental and should be recorded and made known to the client but you are under no obligation to fix or investigate.
I think his nationality might be an issue - sounds like some of his countrymen maybe installed the circuits - part p they don't give a hoot
I have seen it loads of times especially in London.
Not racist but just my observations
As others have said start at the beginning and break it down into sections of testing , otherwise you can be chasing your tail
Don't forget to tell the customer this us going to be expensive - saves on the startled face when you present the bill !!
Yes, most customers have a socket and see.
has same green green red on socket tester today. fault causing this was a blown cable ( L-E short which had melted the cpc and the L wasn't much better). still got no earth on several sockets but socket tester show 3 greens. moral is not to trust a socket tester. they're only a basic tool. there's 55V on the cpc of 6 sockets till we dig up bedroom floor tomorrow. ( thee duff leg is isolated atm, btw).
Which backs up something i was told as a lad...if something/someone is not telling you the FULL story...they could be telling you ANY story :blush5:
Although it is surprising,the number of supposedly "authority" institutions,who routinely send out their operatives,with such devices.
Is it TNCS by any chance?
Possible lost supply neutral and bonding has effectively become the neutral.....??
This may be completely out as you haven't mentioned proving the supply 1st.
Start from the beginning.
It is tncs rich.250. Interesting point & one I haven't come across yet. I did do a polarity check on the incoming which I don't think showed anything wrong if memory serves. I will double check it when I go back tho. Where would the Neutral be lost? It would have to be between the incomer & neutral bar wouldn't it? cheers
Reply to Earth leakage on sockets in the Talk Electrician area at ElectriciansForums.net
Just an update for anyone interested, I got another rod in outside today, which has lowered the Zs db to a more healthy 53ohms. The oven elements...
2 3
