Earth Leakage Query.
telectrix
Mentor
Nearly Esteemed
might be having a blonde moment here, but.... if an installation has earth leakage, could this be measured with an earth leakage clamp meter on the main earthing conductor and/or the main bonding conductors as logically, if there is leakage , you would expect the current to travel to earth through these conductors?
Nothing like the old sets LOPTY big and ugly , nice heat in the workshop off the old PL405 valves.
i have a healthy respect for capacitors, ever since working on 1970's colour TVs. when a section of the crude wire wound dropper resistor went o/c. there would be a nice 200v charge left on the smoothing capacitor. the usual method of discharging this before getting bit big style was to use a 10" blade pozidriv screwy. to s/c the cap. to chasssis. still got my old one with little blackened nibbles.
i was with rediffusion 1972-3. average 18 service calls per day.
was at the rediffusion depot in stoke. my lady's had the all clear last check up. next one in about 4 months time. fingers crossed.
That's brilliant! I was looking for a fast and easy way to check if was going to hold. Do most clamp meters have a m/a range?
I defiantly try it next time I change a board. Tip top!:)
most clamp meters don't have milliamp range. you need a earth leakage clamp meter.
not in maplins i don't think . the alphatek 633 is around £65 + VAT. it's about the cheapest going. try ebay.
