Earth Loop Imp. Test | on ElectriciansForums
Discuss Earth Loop Imp. Test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
E
eagleeye
I have recently done a couple of rewires and tests on TT systems. I use a Di-log 9083P to do aal the required tests. The trouble i am having though is that the bloody thing trips out the RCBO's on Earth fault loop test. The meter is ment to have a function on it that stops it from doing this. So im just trying to find out if anyone else has on of thses testers and if they have the same problem
had google do the work :) send it back some are faulty
look here IET Forums - di log 9083p
Reply to Earth Loop Imp. Test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
"When stoned..." Brilliant!
2 3
