earth return path | on ElectriciansForums
Discuss earth return path in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
leigh,lancashire
hi to all
when asked for external earth return path for a TT system is it
General mass of earth
Supply earth electrode
For TN-C-S system is it
supply PEN conductor
for TN-S
supply protective conductor
thanks
its earthed through
1 consumers earth electrode
2 general mass of earth
3 supplier earth electrode
the question asks earth path external to installation so it cant be number1 as belongs to installation
i also have one that says earth fault path extaernal to istallation
and tutor at college says
TT . General mass of earth
star point
secondary winding
supply lines
supply overcurrent protective device
TN-S
star point
secondary windings
supply line
TN-C-S
PEN conductor
star point
secondary windings
supply line
suppliers overcurrent protective device
thats why i think earth return path for a tt is
Suppliers earth electrode
Upvote 0
Reply to earth return path in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
In TN-S systems, you shouldn't isolate the neutral in a 4-pole isolator. Connecting neutrals to a dedicated terminal is acceptable and safe...
It's not the same scenario, though. Tails more than 3mtrs can be overcome by using a fused switch and rcd board, whether the earthing system is...
Electrical Courses
