Earth Rod - Advice please! | Page 2 | on ElectriciansForums
Discuss Earth Rod - Advice please! in the UK Electrical Forum area at ElectriciansForums.net
K
Kaydee
Hi, I am not an electrician, but need some advice from one, if you wouldn't mind helping, please?
We've just paid ÂŁ3,500.00 to have a 3-bed semi completely rewired and are told the job is now finished. (We paid half up front, they now want the other half).
Outside the front of the property, they've installed what they've told us is an 'earth rod'. There's a long piece of thick, black, plastic tubing, leading to a unit that is fixed to the ground.
It comes almost onto the driveway, right in front of an attractive bush to the side of the front door and looks really unsightly.
We questioned them about it and were told it was 'regulation' that it had to be installed that way, a metre from the house, in a straight line.
I haven't seen anything like this in front of any other property, including ones that have been recently rewired, but want to check my facts before challenging them on this.
Is this normal? Can it/should it be buried underground?
Without sounding out of turn, the electrician should have known that an earth rod needed installing upon surveying the property during quoting purposes. The method you described is quite common and tends to be the cheapest easiest solution. This said, personally I would have discussed this with the client prior to commencing work and made provisions in the quote to install the rod within the regs as per clients spec. As its a "basic" re-wire and we know nothing of your agreed contract with the electrician, its difficult to make comment about your situation.
My guess is he/she will advise that the alterations you require will be charged extra to the original quote if nothing was agreed prior.
I think you're probably right David, but as he knew we were preparing the house for marketing it, I would have hoped he would have discussed this sort of thing with us, which he didn't!
Can you post a picture of the earth rod's current set up? Is your propery in a remote location or do you have other properties close by.? Hard to comment on the price without a full spec but it doesnt sound that unreasonable.
[ElectriciansForums.net] Earth Rod - Advice please!
I'd also like to see a pic. has he installed a decent rod, or just a 3ft. "twig". and is the Ra/Ze suitably low.
Looks okay to me, guess until the bush is cut back!
yeah. it's not as bad as i thought. a bit of greenery planted in front would disguise it. bearing in mind that it should be accessible for maintenance purposes.
Is this normal then? It's just that I've never seen it like this before on other properties.
I'm mainly worried about buyers wondering what it is and what it's doing there.
seen far worse, just a rod banged in with no enclosure whatever. worry not. it's compliant even if you don't like the aesthetics.
Reply to Earth Rod - Advice please! in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
Advice needed regarding sealing? Or Are these tiles faulty? I've recently bought Johnson 'Orkney Stone' ceramic floor tiles from B&Q. Paid to...
drowninginit
