Earth Rod Connection | on ElectriciansForums
Discuss Earth Rod Connection in the UK Electrical Forum area at ElectriciansForums.net
Pip
Ebrington, GL55
Is this an acceptable connection to an earth rod?
And is the water bond really necessary? (New duel RCD board recently fitted)
  • [ElectriciansForums.net] Earth Rod Connection
Hi - that rod looks like it’s seriously rusted so I would not have used it myself. I doubt the clamp has made good connection through that rust, so for me it’s not ok.
Bonding to water may not be required if the incoming main is plastic and there are tests to confirm.
Yes my thoughts exactly, A new board was fitted in April, and the earth/bonding cables upgraded, this is how it was done.
I've reconfigured some circuits in the property and have replaced this connection with a larger clamp, and have a Ze reading of 190 ohm. (Previously fluctuating to any number you want) And have brought the Zs readings down from 213 to 63.7
Will discuss with the client replacing for a new rod.
Incoming main is plastic, and I know they renewed the gas pipe only a year ago also.
Rod is too close to the building. try a new rod ( screwed togehter rods down to about 12 ft. surround rod with a bag of cat litter.
never seen a metal rod before i thought they were all copper? shocking job by the way
They're normally copper coated steel. Solid copper would just bend and buckle when banging it in.
I'll bite; why cat litter? absorbsant material?
yep. it holds moisture. think always and/or tenna lady, see the ads. when wet, it's as good as bentonite, but way cheaper.
Reply to Earth Rod Connection in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
2 3
