Earth rod inspection pit keys | on ElectriciansForums
Discuss Earth rod inspection pit keys in the UK Electrical Forum area at ElectriciansForums.net
Try one of these............
[ElectriciansForums.net] Earth rod inspection pit keys
If Toolstation sell exactly the same pit cover then maybe phone them for a key. I'm sure a couple of flat screwdrivers and a pair of pliers will open the lid, it's probably just stuck with debris around the rim.
when new the keys are actually in a plastic airfix style frame at the top, just below the lid, most people dont even bother to open the lid when installing ive found as the keys are still in their. it will open easy enough with a flat blade screwdriver though
Reply to Earth rod inspection pit keys in the UK Electrical Forum area at ElectriciansForums.net
2 3
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
