View the thread, titled "Earth rod spacing" which is posted in UK Electrical Forum on Electricians Forums.
Hi,
Just a general question, I have never installed an earth rod so don't have any experience in them, but would like to think I know the basics before I come across one I have to install.
My question is, presumably I would be correct in thinking the 3/8 rods are not worth the time and should be not sold, and only 5/8 should really be used, put at least two in connected vertically, depth is best I understand, should I need to install another rod to help bring the reading down, is there a recommended distance the second rod should be from the first one or would putting it a few inches away be ok?
My initial thoughts are that it would be ideal to locate it the same distance away that the first one is long, so if its a 4ft rod, put it at least 4ft from it?
And keep them a couple of meters away from the house where possible. Someone mentioned to me that putting a think 1000mm drill into the ground can help drive it in easier.
I did find a good thread on here this morning about exporting PME, or extending the equi-potential zone so to speak and needing to TT the remote end in some circumstances, it did confirm my thoughts, but made interesting reading.
Actually, ''NOT'' such a great area to place earth rods. Far better to place earth electrodes externally where rain can keep the surrounding soil wet/damp. The damper the surrounding soil, the better will be the contact between soil and electrode, and better will be the Ra values obtained.
The alternative was breaking deep concrete, which I didn't fancy
Ive done 8 metres deep.
Got in at the right time, ongoing deep excavation and just screwed more on as it was later backfilled. If youre not fast, youre last!
Boydy
Clay soil at a deep drainage excavation.
3 multi spikes some 5m apart. 20+ spikes.
First ones driven in at the bottom of the excavation and added to with couplers as backfilling went on.
New Sainsburys.
Dont remember the Ra (4 yrs ago) but I do remember being disappointed although it was a personal best.
Boydy
New Sainsburys.
Boydy
A few nectar points for that though, I'll bet.:smile5:
Reply to the thread, titled "Earth rod spacing" which is posted in UK Electrical Forum on Electricians Forums.
