Earth Sparkin (not ur usual......) | on ElectriciansForums
Discuss Earth Sparkin (not ur usual......) in the UK Electrical Forum area at ElectriciansForums.net
Ipswich
Testing an installation - RCD's not testing properly (can get a good test occasionally.?)- Newish Megger recently calibrated
just tested RCD's at home and all good
All MCB's off, RCD's off, main switch off and main fuse removed, no alternative supplies
can get a good tingle off of the earth - disconnected earth bonding to water (no gas or oil etc) and main earth bond no voltage on consumer unit earth bar measured
PME installation - overhead supply - old uninsulated neutral style (N-L 243v , L-E 243v)
ALL circuits test perfectly IR, R1R2, ZE, ZS etc (supply 0.16 ohm Ze same as main bond approx 450mm long)
Can get a goodly spark to the earth bar in the consumer unit from either.... - have a video of this - showing exactly above
cannot measure a voltage across either and earth in the consumer unit common but they spark
Realise there will be earth potential on water pipework etc
Any ideas ?
It sounds like the circulating currents that are common in PME, with some current from other installations returning to the transformer via your bonding and the earthed services. It's not necessarily a problem, seeing as you are not getting a significant voltage discrepancy or high Ze that would indicate a broken PEN. It might be an indication of why PME specifies a larger minimum size of MEB conductor, and why the gas meter people put a cable across the meter pipework before removing or fitting a meter, to avoid exactly that spark.
I don't think it is necessarily related to the RCD behaviour.
Hi
Thanks for that
Surely any circulating currents would effect the rcd operation - I can get a good test on both rcd's sporadically -was there almost three hours and tested rcd's randomly many times over that period - 50% success , often two or three tests on the trot good..
Surely this cannot be acceptable ?
Would the DNO be able to check / sort ?
No, as the RCD measures the imbalance between L & N, is it not looking at any CPC current that might be circulating (assuming it is an RCD and not an ancient VOELCB).
Now if you have an N-E fault it could be a different situation, as you might have some anti-phase current in the N making the trip threshold for the RCD test higher than usual, etc. But you should always (and apparently already have) have checked the global IR (overall L+N to E) situation first before wondering about potential RCD issues.
Surely if you have circulating currents on a pme system when a second earth via water pipes etc is introduced this would affect the rcd ?
Reply to Earth Sparkin (not ur usual......) in the UK Electrical Forum area at ElectriciansForums.net
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
4-5 hours for 150? no chance, this is 2024, 150 for 2 hours maybe, that said an hour seems pretty quick, not sure he did the job right
